Hy, I have some automation hat and I want to count form 3 Input (0->1->0) or (1->0->1) (SET-RESET) but with python library I’cant read fast as chip … there is a way ??
thanks
thanks
How fast is the chip driving those inputs? What chip is it? How accurate do you need to count?
The Pi isn’t well suited to this kind of task, but there may be workarounds depending on your application.
1pulse every 2 second
I use Automation hat with “buffer” on input…
I suppose is possibile to reach this interval
Hmm, that shouldn’t be tricky!
I’d probably use RPi.GPIO directly and so something like:
import RPi.GPIO as GPIO
counter = 0
GPIO.setmode(GPIO.BCM)
GPIO.setup(26, GPIO.IN) # Set up input 1
def count_pin(channel):
global counter
counter += 1
GPIO.add_event_detect(26, GPIO.FALLING, callback=count_pin) # May need GPIO.RISING depending on your device
print("Counter: {}".format(counter))
time.sleep(1)
ehm I use:
import automationhat
varname = automationhat.input.one.read();
Your sample is direct with GPIO …
import sys
if automationhat.is_automation_hat():
automationhat.light.power.write(1)
input3counter = 0
input2counter = 0
input1counter = 0
a = False
input3 = automationhat.input.three.read()
if input3 == True :
input3counter = input3counter +1
print('read3' + str(input3counter) )
input2 = automationhat.input.two.read()
if input2 == True :
input2counter = input2counter +1
print('read2' + str(input2counter) )
input1 = automationhat.input.one.read()
if input1 == True :
input1counter = input1counter +1
print('read1' + str(input1counter) )
time.sleep(0.5)
This not working … when “automationhat.input.three.read()” all input will reset !!!
What do you mean by “all input will reset.” If your inputs are being asserted by an external device they will always be at the logic level supplied to them.
To put it another way; If your input.three.read() doesn’t happen to coincide with the point at which your pulse is happening, it will always read False.
