Blinkt! software can't be installed: error: externally-managed-environment
When installing the software needed for the Blinkt! LED board as described in your instructions, I always get an error message like this:
Installing Blinkt! library for Python 3...
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
    python3-xyz, where xyz is the package you are trying to
    install.
hint: See PEP 668 for the detailed specification.
Python 3 library install failed!
If problems persist, visit forums.pimoroni.com for support
I opted in for a full installation incl. docs and examples. What did NOT help:
  • Using sudo when installing: sudo curl https://get.pimoroni.com/blinkt | bash
  • Installing Python 3 in full beforehand: sudo apt-get install python3-full
I’ve got a Pi Zero with the official 32-bit version of Raspi OS I wrote on the SD card by using the Raspi imager. This is my system version: Linux pizero 6.6.51+rpt-rpi-v6 #1 Raspbian 1:6.6.51-1+rpt3 (2024-10-08) armv6l GNU/Linux
A Stack Overflow thread says something about the need to install Python in a venv, but this is hard and tedious work.
What is wrong here?
Dirty way:
sudo mv /usr/lib/python3.11/EXTERNALLY-MANAGED /usr/lib/python3.11/EXTERNALLY-MANAGED.old
Adjust to your python (main) version (see python -V).
Is there no clean way? The dirty one would get overwritten after every update of the Python subsystem.
Try installing from this branch - I think the repackaged installer should try and set up a venv for you if you don’t have one:
You’ll need to activate the virtual environment before running examples, with
source ~/.virtualenvs/pimoroni/bin/activate
OK, thank you. Installation works now without errors, but the LEDs still don’t show anything.
