I might try to wrangle it into a blog post and then cross-link it from the product page and the tutorial.
I think from a very basic point of view, run the sensor for 24 hours reading the raw resistance values, as you are, look at the data, and then decide where to set the baseline. That’s a more sensible way than relying on the way that my script does it.
So, essentially, it would be:
#!/usr/bin/env python
import bme680
sensor = bme680.BME680()
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_gas_status(bme680.ENABLE_GAS_MEAS)
sensor.set_gas_heater_temperature(320)
sensor.set_gas_heater_duration(150)
sensor.select_gas_heater_profile(0)
start_time = time.time()
curr_time = time.time()
try:
gas_baseline = INSERT_BASELINE_VALUE_HERE
hum_weighting = 0.25
if sensor.get_sensor_data() and sensor.data.heat_stable:
gas = sensor.data.gas_resistance
gas_offset = gas_baseline - gas
hum = sensor.data.humidity
hum_offset = hum - hum_baseline
if hum_offset > 0:
hum_score = (100 - hum_baseline - hum_offset) / (100 - hum_baseline) * (hum_weighting * 100)
else:
hum_score = (hum_baseline + hum_offset) / hum_baseline * (hum_weighting * 100)
if gas_offset > 0:
gas_score = (gas / gas_baseline) * (100 - (hum_weighting * 100))
else:
gas_score = 100 - (hum_weighting * 100)
air_quality_score = hum_score + gas_score
print("Gas: {0:.2f} Ohms,humidity: {1:.2f} %RH,air quality: {2:.2f}".format(gas, hum, air_quality_score))
time.sleep(1)
except KeyboardInterrupt:
pass
