I am using a Pi Zero W with the pibow case and a breakout garden pHAT on top. I do not have a room temperature thermometer to take baseline readings but based on this setup I am not sure if the BME680 will experience much temperature offset due to the heat from the RPI0’s CPU temp.
What temperature offset should I use in Celsius if any? I am currently using a wonderful python script that uses a C program linked with the official Bosch library: https://github.com/rstoermer/bsec_bme680_python
I updated the code to use the latest BSEC library version 1.4.7.4. The default temp offset in there is 5C. I also removed the MQTT stuff for now.
After running for a few hours, I am getting numbers like this:
{‘IAQ_Accuracy’: 1.0, ‘IAQ’: 120.6, ‘Temperature’: 28.4, ‘Humidity’: 51.3, ‘Pressure’: 1012.7, ‘Gas’: 230498.0, ‘Status’: 0.0}
Although initially the IAQ was lower at around 30-40. It seemed to ramp up suddenly after a while. Though the sensor readings seem to be staying steady with a bit of variation as I opened the window and let cold air in. Is that weird?
