What is the under control panel clearance space for a joystick on the 2018 model? I would love to use a Mag-Stik-Plus but their mechanism appears to be much deeper than a Sanwa and other common joysticks. For reference see https://smile.amazon.com/dp/B077KDFB86/?coliid=I3RVPI8INXFZQ8&colid=C07KW4KX4VOD&psc=1&ref_=lv_ov_lig_dp_it
Hi, did you get an answer or try this in the end? I’m finally thinking of doing the exact same thing!
Specs of the stick say it’s 71mm from plate to end of the shaft, measuring the picade control panel depth suggests it’s going to be pretty tight. Difficult to know exactly though as the control panel is at a slight angle.
