CLIPPER LTE Mini HAT does not start
Hi, I have a CLIPPER LTE installed on my Raspi Zero 2 w, and everything works fine until I unplug it. It won’t boot again. To get it to boot, I have to unplug it and plug it back in.
Thanks for the help.
Best regards.
When you say “unplug it” What is it? Do you mean the Pi Zero 2 power supply?
Hello.
I mean, I disconnected the 5V.
And when I reconnected the 5V, the Raspi boots up, but the CLIPPER LTE doesn’t start, and the LEDs don’t light up either.
Everything is setup as per the getting started guide?
Hello.
Everything is configured according to the guide. In fact, it works correctly until I disconnect it from the 5V power supply.
If I wait 5 minutes, it boots correctly when I reconnect it to 5V.
OK, hmm, I don’t own one, just so you know. I was hoping it would be something obvious / easy to solve.
I have the same problem. Has somebody fix for the problem. chatGTP calls it Zombie-Mode. But I couldn’t find a solution. Unplug and wait for 5 minutes that the condensers can unload is not an option.
There is a solution for the Zombie-Mode
#!/usr/bin/env python3
Minimales Boot-Script für Crontab @reboot
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(24, GPIO.OUT)
GPIO.output(24, GPIO.LOW) # 0V
time.sleep(1)
GPIO.output(24, GPIO.HIGH) # 3.3V (bleibt)
GPIO.cleanup(24)
