Hi all,
I nabbed a Clipper LTE breakout when they first came out a few weeks back. To be very clear it works perfectly well under the “official” MicroPython build with its baked-in PPP/LTE module.
The (already substantially written, unfortunately) project I’m looking to integrate the breakout into happens to be in CircuitPython, which doesn’t benefit from generic PPP support as it doesn’t lean on MP’s network module. That’s ok though, as I can just write a UART wrapper to do exchange basic AT-style commands with the board - this works fine for HTTP and MQTT.
Here’s my problem: it looks like the SIMCOM A7683E module on the Clipper suffers from an issue common to a lot of the A76XX series - its built-in support for HTTPS actions (GET/POST) is broken. This isn’t a problem on MP or Linux because the SSL session would be done on the host and channeled via PPP.
SIMCOM have only recently begun to discover and address this as an increasing number of Chinese (LilyGo etc.) boards are circulating with confused users. Unlke those other A76XX chips they haven’t yet released a fixed firmware for the A7683E specifically but if they do I don’t think we have the ability to flash any update without using the testpads on the bottom of the board to access the differential pins.
If there’s any plan for the Pimoroni crew to bring a driver/PPP integration to CircuitPython then this issue would be moot but that would be a big undertaking so I wouldn’t expect it!
For now though, I wanted to a) flag this up so it’s known to anyone else looking to use their Clipper outside the current example firmware; b) ask whether anyone can identify the USB +/- test pads for if/when SIMCOM release a fix; and c) check in on whether there’s any chance at all team Pimoroni plan to bring a driver to CircuitPython.
Kind regards,
Greg
