Explorer Phat and Hc-SR04 range sensor (again)
I know there is a post from 2015 on this subject, to save people reading through all of the earlier posts, I thought it might be best to start again.
So I am helping someone build a robot, they have got a PI zero, explorer Phat, two 50;1 micro motors etc. That side is ok.
we want to use a HC-Sr04 range sensor. As this is a 5 volt device I thought we could connect to the 5volt input / outputs on the explorer hat.
we are using input 1 for the echo and output 1 for the trigger with the following gpiozero code.
from gpiozero import DistanceSensor
from time import sleep
sensor = DistanceSensor(echo=23, trigger=6)
print('Distance: ', sensor.distance * 100)
sleep(1)
Echo is on gpio23 and trigger on gpio 6 as per the explorer hat documentation.
When we do get a reading it is in correct.
I notice in the technical documentation for the board there is a comment about the outputs sinking current to ground when turned on and having to connect device to a voltage supply and then to the output pin.
does anyone know how this relates to the distance sensor, e.g. i have got to wire the sensor up differently, I am confuse at the moment.
If we connect the sensor direct to the PI using a potential divider on the echo pin as per the GPIO example, then it works.
thanks
Steve
A 10K pull up on the trigger solves the problem, and then invert the logic.
To generate the pulse for the trigger
output a 1 to pull the trigger low, wait 10micro secs then write a 0 to pull it high. I now get a consistent reading to less with noise of +/- 0.25 cm, more than adequate for my needs.
having sorted it, I have just seen more replies to an earlier post where they suggest the same solution.
On to the next problem/
Steve
Could you give any more details on what your circuit was and the code you used? Aiming to do something similar in the next couple of days and a pointer or two would speed things up greatly :D
Here is a copy of the code with comments!
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
TRIG = 6 # op1 pull up resistor fitted between Vcc and the trigger pin
ECHO = 23 # ip1
print “Distance Measurement In Progress”
GPIO.setup(TRIG,GPIO.OUT)
GPIO.setup(ECHO,GPIO.IN)
GPIO.output(TRIG, True)
print “Waiting For Sensor To Settle”
time.sleep(1)
GPIO.output(TRIG, False)
time.sleep(0.00001)
while GPIO.input(ECHO)==0:
  pulse_start = time.time()
while GPIO.input(ECHO)==1:
  pulse_end = time.time()
pulse_duration = pulse_end - pulse_start
distance = pulse_duration * 17150
distance = round(distance, 2)
print "Distance:",distance,"cm"
time.sleep(1)
GPIO.cleanup()
one day I will get the hang of mark up text and make it a code block, think it has lost the indents, hopefully it wont be too difficult to sort out!
Steve
Thanks Steve for solving the problem. I have modified your code to make sure the GPIO.cleanup() method is executed. Now when the program is terminated using Control + C on the keyboard, the code handles the error and cleans the GPIO allocations.
I have included a pic of the wiring which I used successfully for the HC-SR04 and the Explorer Hat Pro.
