Hi all
I just installed a fanshim on my pi4.
it turns on when I boot up the pi, but then it seems not to respond to my commands :(
pi@raspberrypi:~ $ ./fanshim.sh
No argument specified, setting ON to 55C and OFF to 45C
Setting up with:
Off Threshold: 45 C
On Threshold: 55 C
Low Temp: 45 C
High Temp: 55 C
Delay: 2 seconds
Preempt: no
Disable LED: no
Disable Button: no
Brightness: 255
Extended Colours: no
To change these options, run:
sudo ./install-service.sh --off-threshold --on-threshold --delay --brightness --low-temp --high-temp --venv <python_virtual_environment> (–preempt) (–noled) (–nobutton) (–extended-colours)
Or edit: /etc/systemd/system/pimoroni-fanshim.service
Checking for rpi.gpio >= 0.7.0 (for Pi 4 support)
rpi.gpio >= 0.7.0 already installed
Checking for Fan SHIM
Fan SHIM already installed
Checking for psutil >= 5.6.7
psutil >= 5.6.7 already installed
Installing service to: /etc/systemd/system/pimoroni-fanshim.service
● pimoroni-fanshim.service - Fan Shim Service
Loaded: loaded (/etc/systemd/system/pimoroni-fanshim.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-09-02 21:19:27 CEST; 26ms ago
Main PID: 4339 (python3)
Tasks: 1 (limit: 4915)
CGroup: /system.slice/pimoroni-fanshim.service
└─4339 /usr/bin/python3 /home/pi/automatic.py --on-threshold 55 --off-threshold 45 --low-temp 45 --high-temp 55 --delay 2 --brigh…
Sep 02 21:19:27 raspberrypi systemd[1]: Started Fan Shim Service.
pi@raspberrypi:~ vim /etc/systemd/system/pimoroni-fanshim.service
pi@raspberrypi:~ ./temperature.py
temp=59.0’C
Fan status is: 0
pi@raspberrypi:~ $ ./temperature.py
temp=64.0’C
Fan status is: 0
Basically I’m setting the fan to turn on between 45 and 55, but as you can see the fan stays off even when the temp is 59 or 64 degree. the led doesn’t turn on at all…
if I use automatic.py script, I can see the led working and the fan turning on and off…
