My fanshim never really quite worked from the start, and I haven’t been able to find a solution to any problems that are quite like mine.
When not running the automatic.py script, the LED stays off and the fan stays in dummy mode (just cooling). This is as expected.
When running the automatic.py script, however, the LED comes on but the fan does not turn off when well below the off threshold. The LED changes color as the pi heats up, but the fan never stops spinning.
I would reattach the fan shim. Maybe even press down on it or tilt it slightly and see if the fan works normally. Best guess is the fan control pin isn’t making a good contact.
I do believe that pin is pulled low (grounded) to turn the fan off.
Yes the contacts aren’t reliable. I screwed mine down through the RPI mounting hole with a 3D printed spacer because the vibration made it move around and touch my case lid. It then stopped working and I had to release the screw a little to get it to work again.
I soldered mine to a booster header. I just left out those two spacer nuts when mounting the fan to the holder to lower it back down a bit. I also have the heatsink attached so I need a bit of space between the fan and the heatsink anyway.
Hello everyone,
i find a simple solution of this problem i insert a little piece of cotton swab in the gpio connettor in order to enlarge the pins and it works very well with no soldering at all.
I currently have a stock fan shim (not soldered) with my Blinkt plugged in on top. It’s working as advertised. I can’t access the button this way though? Not easily anyway.
One thing I may try is removing the pins from a male header, and then pushing the black part that holds the pins in place, down over the Pins on the Pi, on top of the Fan shim to hold it firmly down. If need be down the road it could be removed again with a little pulling. I’d only put it over the 12 pins the Fan shim uses.
