I have some code I’m running on my Tufty I will post at the end.
The plan was to have it show the battery voltage and % left when on battery across the top of the screen. This works via the usb_power function. And when on USB power and plugged into my desktop PC, show the Time and Date instead of the battery info. This sort of works.
Time and Date display, with the correct time and date if I run my file “from” Thonny. If I just turn on the tufty, while plugged in, I get 0:00~AM and 01:01:2021. It never syncs the time with the PC.
Question is, is there a quick and dirty way to have it get the time from the host PC?
I will likely add an RV3028 at some point. Still, I got to wondering if i could get this to work anyway?
import machine
import picographics
from picographics import PicoGraphics, DISPLAY_TUFTY_2040, PEN_RGB332
display = PicoGraphics(display=DISPLAY_TUFTY_2040, rotate=180, pen_type=PEN_RGB332)
display.set_backlight(1.0)
display.set_font("bitmap8")
rtc = machine.RTC()
#rtc.set_time(second, minute, hour, weekday, day, month, year)
print(f"Getting time from Pico RTC/Thonny: {rtc.datetime()}")
year, month, day, weekday, hour, minute, second, microsecond = rtc.datetime()
from breakout_bme280 import BreakoutBME280
i2c = PimoroniI2C(sda=(4), scl=(5))
bme = BreakoutBME280(i2c)
from machine import ADC, Pin
# set up the ADCs for measuring battery voltage
vbat_adc = ADC(29)
vref_adc = ADC(28)
vref_en = Pin(27)
vref_en.init(Pin.OUT)
vref_en.value(0)
usb_power = Pin(24, Pin.IN) # reading GP24 tells us whether or not USB power is connected
# Reference voltages for a full/empty battery, in volts
# the values could vary by battery size/manufacturer so you might need to adjust them
# Values for a Galleon 400mAh LiPo:
full_battery = 3.7
empty_battery = 2.5
from pimoroni import Button
button_a = Button(7, invert=False)
button_b = Button(8, invert=False)
button_c = Button(9, invert=False)
button_up = Button(22, invert=False)
button_down = Button(6, invert=False)
button_boot = Button(23, invert=True)
tempcolor = display.create_pen(0, 255, 0) # this colour will get changed in a bit
humidcolor = display.create_pen(0, 255, 0) # this colour will get changed in a bit
presscolor = display.create_pen(0, 255, 0) # this colour will get changed in a bit
white = display.create_pen(255, 255, 255)
black = display.create_pen(0, 0, 0)
red = display.create_pen(255, 0, 0)
green = display.create_pen(0, 255, 0)
blue = display.create_pen(0, 0, 255)
yellow = display.create_pen(255, 255, 0)
orange = display.create_pen(255, 140, 0)
grey = display.create_pen(120, 120, 120)
violet = display.create_pen(255, 0, 255)
cyan = display.create_pen(0, 255, 255)
start_time = time.time()
display.set_pen(black)
display.clear()
# converts the temperature into a description and pen colour
def describe_temperature(temperature):
global tempcolor
if temperature <= 0:
description = "Very Cold"
tempcolor = blue
elif 0 < temperature <= 12:
description = "Cold"
tempcolor = yellow
elif 12 < temperature < 17:
description = "Cool"
tempcolor = green
elif 17 <= temperature <= 24:
description = "OK"
tempcolor = green
elif 24 < temperature <= 27:
description = "Hot"
tempcolor = orange
elif temperature > 27:
description = "Very Hot"
tempcolor = red
else:
description = ""
tempcolor = black
return description
# converts humidity into good/bad description and pen color
def describe_humidity(humidity):
global humidcolor
if humidity < 30:
description = "Low - Dry"
humidcolor = orange
elif 30 <= humidity <= 60:
description = "OK"
humidcolor = green
elif 60 < humidity < 80:
description = "High"
humidcolor = yellow
elif humidity >= 80:
description = "Very High"
humidcolor = red
else:
description = ""
humidcolor = black
return description
# converts pressure into barometer-type description and pen color
def describe_pressure(pressure):
global presscolor
if pressure < 982:
description = "Very Low"
presscolor = red
elif 982 <= pressure < 1004:
description = "Low"
presscolor = yellow
elif 1004 <= pressure < 1026:
description = "OK"
presscolor = green
elif 1026 <= pressure < 1048:
presscolor = blue
elif pressure >= 1048:
presscolor = orange
else:
description = ""
presscolor = black
return description
def draw_graph(temp_value, press_value, humid_value):
scaled_temp = int((temperature * 5) + 160)
scaled_humid = int((humidity * (320 / 100)) - 10)
scaled_press = int(((pressuremb - 960) * 3) - 10)
display.set_pen(tempcolor)
display.rectangle(0, 80, (scaled_temp), 19)
display.circle((scaled_temp), 89, 9)
display.text("{:0.0f}c".format(temperature), 0, 40, scale=4)
display.text(describe_temperature(temperature), 150, 40, scale=4)
display.circle((scaled_temp), 89, 5)
display.set_pen(humidcolor)
display.rectangle(0, 150, (scaled_humid), 19)
display.circle((scaled_humid), 159, 9)
display.text("{:0.0f}%".format(humidity), 0, 110, scale=4)
display.text(describe_humidity(humidity), 150, 110, scale=4)
display.circle((scaled_humid), 159, 5)
describe_pressure(pressuremb)
display.set_pen(presscolor)
display.rectangle(0, 220, (scaled_press), 19)
display.circle((scaled_press), 229, 9)
display.text("{:0.0f}mb".format(pressuremb), 0, 180, scale=4)
display.text(describe_pressure(pressuremb), 150, 180, scale=4)
display.circle((scaled_press), 229, 5)
rtc.datetime((year, month, day, 0, hour, minute, second, 0))
if button_a.is_pressed:
print ("Button A pressed")
elif button_b.is_pressed:
print ("Button B pressed")
elif button_c.is_pressed:
print ("Button C pressed")
elif button_up.is_pressed:
elif button_down.is_pressed:
display.set_backlight(0.5)
elif button_boot.is_pressed:
print ("Button BOOT/USR pressed")
time.sleep(1)
time_elapsed = time.time() - start_time
year, month, day, wd, hour, minute, second, _ = rtc.datetime()
last_second = second
temperature, pressure, humidity = bme.read()
pressuremb = pressure / 100
draw_graph(temperature, pressure, humidity)
temperature = round(temperature)
humidity = round(humidity)
pressure = round(pressure)
vref_en.value(1)
vdd = 1.24 * (65535 / vref_adc.read_u16())
vbat = (
(vbat_adc.read_u16() / 65535) * 3 * vdd
vref_en.value(0)
# Print out the voltage
print("Battery Voltage = ", vbat, "V", sep="")
# convert the raw ADC read into a voltage, and then a percentage
percentage = 100 * ((vbat - empty_battery) / (full_battery - empty_battery))
if percentage > 100:
percentage = 100
if percentage < 0:
percentage = 0
if usb_power.value() == 1:
display.set_pen(cyan)
display.text(f"{day:02}:{month:02}:{year:02}", 180, 0, scale=3)
#display.text("year, month, day,rtc_date", 170, 0, scale=3)
if hour <10:
display.text(f"{hour:1}:{minute:02}~AM", 0, 0, scale=3)
elif 10 <= hour < 12:
display.text(f"{hour:2}:{minute:02}~AM", 0, 0, scale=3)
elif hour == 12:
display.text(f"{hour:2}:{minute:02}~PM", 0, 0, scale=3)
elif hour >12:
hour = hour - 12
if hour <10:
display.text(f"{hour:1}:{minute:02}~PM", 0, 0, scale=3)
elif hour == 12:
else:
if percentage >= 50:
display.set_pen(green)
display.text("Battery", 0, 0, scale=3)
display.text("{:0.2f}v".format(vbat), 150, 0, scale=3)
display.text("{:0.0f}%".format(percentage), 255, 0, scale=3)
elif 50 < percentage > 20:
display.set_pen(yellow)
elif percentage <= 20:
display.set_pen(red)
if time_elapsed < 0.5:
display.clear()
display.update()
time.sleep(1)
else:
display.update()
time.sleep(1)
display.clear()
time.sleep(1)
