I have got the tracker program working, however, the camera tilts up to max a few seconds after starting. I have tried changing the default position for the camera but it seems to make no difference. Is there another line I should try changing to have the camera not tilt at the start? # Default Pan/Tilt for the camera in degrees. # Camera range is from -90 to 90 cam_pan = 90 cam_tilt = 0 (default is 60)
The cam_tilt value is in degrees of the total range of camera movement, so a value of 0 would be (I think) fully tilted upwards, and a value of 180 would be fully tilted downwards.
You’ll need to start with 90 and add/subtract as necessary.
Looking back over my code it looks like I’ve confused things by saying:
cam_pan = 90
cam_tilt = 60
And then doing this:
# Turn the camera to the default position
pan(cam_pan-90)
tilt(cam_tilt-90)
So that a cam_tilt value of 0 would result in -90 being sent to the PanTilt HAT.
