Hello, I’m trying to configure my new Hyperpixel 4 square to my RPi 4, I already managed to get it to work but I can’t get it to rotate automatic in config.txt.
Here is my config.txt
dtoverlay=vc4-fkms-v3d
dtoverlay=hyperpixel4
dtparam=rotate=90,touchscreen-swapped-x-y,touchscreen-inverted-y
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x7f216
dpi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 32000000 6```
If I put 'DISPLAY=:0.0 sudo hyperpixel4-rotate right' on terminal it rotates the display and the touchscreen works great, but I can't change it on the config.txt.
Hope anybody can help me.
Thanks.
Muts
February 14, 2023, 8:42am
2
Hello,
Do you have the latest OS, Bullseye running on you RPi4?
You say you have the square one, so maybe you need to use
dtoverlay=vc4-kms-dpi-hyperpixel4sq
instead of two dtoverlay’s you use now.
Rotate for the square use, make sure it is right after the dtoverlay line:
dtparam=rotate=90 - Header is on the left (wonky touch, see below)
dtparam=rotate=180 - Header still on the top (doesn't work? Same as default)
dtparam=rotate=270 - Header is on the right (wonky touch, see below)
It is not that I’m a smart boy, I just read this page:
opened 05:25PM - 11 Apr 22 UTC
notice
:warning: PSA: Make sure you disable i2c, SPI and any other interfaces since the… se will cause a conflict in device-tree with HyperPixel :warning:
:warning: A fresh image is recommended, but otherwise make sure you also disable the `hyperpixel4-init` system service! :warning:
Pi 3B and Pi 4 users running the latest and greatest Raspberry Pi OS should forego our installer and use the instructions below.
> :information_source: If you're tied to an older OS and you want to install the legacy drivers, use:
> `curl -sSL get.pimoroni.com/hyperpixel4-legacy | bash`
This new OS can currently be found in Raspberry Pi Imager under "Raspberry Pi OS (Other)"
Once installed you need only one line in `/boot/config.txt`:
* Rectangular: `dtoverlay=vc4-kms-dpi-hyperpixel4`
* Square: `dtoverlay=vc4-kms-dpi-hyperpixel4sq`
You can rotate these in config.txt by adding the `rotate=` parameter, like so:
dtoverlay=vc4-kms-dpi-hyperpixel4sq,rotate=90
This supports rotation in console, too, for all you CyberDeck builders!
## HyperPixel 4 Rectangular Rotations
Ensure rotation is set to "Normal" in "Display Configuration"
And that the dtoverlay is in `/boot/config.txt`:
Finally use one of the following `dtparam` lines immediately underneath to set the parameters:
* The default is portrait with header on the right, no extra line needed
* `dtparam=rotate=90,touchscreen-swapped-x-y,touchscreen-inverted-y` - Landscape with header on the bottom
* `dtparam=rotate=180` - Portrait with header on the left
* `dtparam=rotate=270,touchscreen-swapped-x-y,touchscreen-inverted-x` - Landscape with header on the top
## HyperPixel 4 Square Rotations
HyperPixel 4 Square does not correctly swap or invert touch input, so you may want to use the Xorg config method below.
* Default is header on the top
* `dtparam=rotate=90` - Header is on the left (wonky touch, see below)
* `dtparam=rotate=180` - Header *still* on the top (doesn't work? Same as default)
* `dtparam=rotate=270` - Header is on the right (wonky touch, see below)
:warning: The `touchscreen-swapped-x-y` parameter does not seem to work with Square. You may need to use the script below for Raspberry Pi OS with Desktop.
## On the fly rotation
Rotating the display via "Screen Configuration" ("arandr") results in inverted touch input and other weirdness- use the dtoverlay params.
If you want to rotate on the fly you can use the below bash script to rotate either display and persist settings into Xorg configuration files.
:warning: Note: You *must* remove the `rotate=` argument from `/boot/config.txt` for these to make sense.
You can remove the rotation config by deleting the `/usr/share/X11/xorg.conf.d/88-hyperpixel4-touch.conf` and `/usr/share/X11/xorg.conf.d/88-dsi-1-rotate.conf` files.
```bash
#!/bin/bash
UTILITY="hyperpixel4-rotate (Rectangular)"
XORG_TOUCH_CONF_FILE="/usr/share/X11/xorg.conf.d/88-hyperpixel4-touch.conf"
XORG_CONF_FILE="/usr/share/X11/xorg.conf.d/88-dsi-1-rotate.conf"
OVERLAY_S="vc4-kms-dpi-hyperpixel4sq"
OVERLAY_R="vc4-kms-dpi-hyperpixel4"
function success() {
echo -e "$(tput setaf 2)$1$(tput sgr0)"
function inform() {
echo -e "$(tput setaf 6)$1$(tput sgr0)"
function warning() {
echo -e "$(tput setaf 1)$1$(tput sgr0)"
function set_xorg_conf {
if [ "$DISPLAY" == "" ]; then
inform "No DISPLAY variable set, trying :0.0"
export DISPLAY=:0.0
fi
inform "Rotating display $1";
xrandr --output DPI-1 --rotate $1
MATRIX="$2 $3 $4 $5 $6 $7 $8 $9 ${10}"
inform "Setting libinput Calibration Matrix: 1 0 0 0 1 0";
xinput set-prop "pointer:$DEVICE" "libinput Calibration Matrix" 1 0 0 0 1 0 0 0 1
inform "Setting Coordinate Transformation Matrix: $MATRIX";
xinput set-prop "pointer:$DEVICE" "Coordinate Transformation Matrix" $MATRIX
inform "Saving xorg touch config to $XORG_TOUCH_CONF_FILE";
sudo tee $XORG_TOUCH_CONF_FILE > /dev/null <<EOF
# Auto generated by $UTILITY, edit with care!
Section "InputClass"
Identifier "HyperPixel4 $DEVICE"
MatchProduct "$DEVICE"
Option "CalibrationMatrix" "1 0 0 0 1 0 0 0 1"
Option "TransformationMatrix" "$MATRIX"
EndSection
EOF
inform "Saving xorg rotate config to $XORG_CONF_FILE";
sudo tee $XORG_CONF_FILE > /dev/null <<EOF
Section "Monitor"
Identifier "DPI-1"
Option "Rotate" "$1"
EndSection
EOF
printf "HyperPixel 4: Display & Touch Rotation\n"
printf "This utility requires the Raspberry Pi OS desktop or an *Xorg-based* alternative.\n\n"
ORIENTATION=$1
grep -e "^dtoverlay=$OVERLAY_S.*" /boot/config.txt > /dev/null
if [ $? -ne 0 ]; then
grep -e "^dtoverlay=$OVERLAY_R.*" /boot/config.txt > /dev/null
warning "Rotation requires hardware support on the Pi 4 or Pi 400"
warning "Ensure your HyperPixel4 is enabled in /boot/config.txt"
printf "\nSquare: dtoverlay=$OVERLAY_S\n"
printf "Rectangular: dtoverlay=$OVERLAY_R\n\n"
exit 1
else
inform "Detected HyperPixel 4 Rectangular (found \"$OVERLAY_R\" in config.txt)"
DEVICE="Goodix Capacitive TouchScreen"
fi
else
inform "Detected HyperPixel 4 Square (found \"$OVERLAY_S\" in config.txt)"
DEVICE="EP0110M09"
fi
case $ORIENTATION in
"right")
set_xorg_conf $ORIENTATION 0 1 0 -1 0 1 0 0 1
"left")
set_xorg_conf $ORIENTATION 0 -1 1 1 0 0 0 0 1
"inverted")
set_xorg_conf $ORIENTATION -1 0 1 0 -1 1 0 0 1
"normal")
set_xorg_conf $ORIENTATION 1 0 0 0 1 0 0 0 1
printf "Unsupported orientation: $ORIENTATION\n\n";
printf "Usage:\n"
printf " $0 <orientation>\n\n"
printf "Where orientation is one of: left, right, normal, inverted.\n"
exit 1
esac
Let us know if it worked for you.
