I'm looking for a metallic (or plastic) case for the display HyperPixel 4.0 Square - Touch
Hello to everyone.
I’m looking for a metallic (or plastic) case (or protective enclosure) for the display HyperPixel 4.0 Square - Touch.
Thanks so much.
Can you print yourself? If so, head on to printables.com and search for hyperpixel. There are many hits.
I can’t print it by myself. I should ask to a company. And anyway the 3d models that I’ve found aren’t like I want. I should modify the most close. But I never used a CAD software…
I started with Tinkercad (tinkercad.com). It is very intuitive. And it takes long until you outgrow it.
But if you can’t print yourself, you still have a problem. I went also this route in the beginning. It does work, but often when designing your own models it is trial and error and that makes it expensive and tedious when you order your print.
Exactly. I know. But I can’t buy a 3D printer. I don’t have the money. So,I must be very sure the 3D model I create was perfect.
