Inky frame 7.3" - Update problem: nothing happens
Hi all,
My inky frame has been sitting and doing its job for a over 1.5 years now: every few hours pick a random image + weather info + date and display it.
Today I noticed the date was incorrect. This happens sometimes, usually a reset / power cycle gets things going again.
Today that did not work.
The pico seems fine. I can connect per USB and my scripts prints will work as expected.
When it comes to calling the graphics.update function, it returns near instant. The screen is not updated.
I don’t really know how to debug this.
For far I’ve tried updating to the latest version, so its now running pico_w_inky-v1.26.1.
The update did not help, I did add a set_blocking(True), since it seems non-blocking by default now.
How to proceed debugging what is wrong with the screen? I am suspecting something is just broken, there is however no visual damage.
Since the Pico is fine and everything was running ok for more than a year, I would guess that the “display” is broken. You could check the display connector on the back, but there is no good reason why the FPC-cable from the display isn’t seated anymore.
A “broken display” can be anything: the driver chip or some support electronics. Carefully inspecting the back side may give a hint, but I don’t think there is anything you can do even if you find something.
Thanks for your reply.
That is what I was thinking. Visually I see no damage but it could be microscopic.
If someone has ideas for debugging the connection to the display I’m all ears.
You could try to trace the signals on the Pico side. But all you would know is that the Pico is sending the correct data across the SPI-bus. Which is probably the case.
On the Inky-Frame side, the support electronics for the display is more or less power-related. You could measure the power-levels directly on the FPC connector, but you really need a small probe for that. And you would have to know which power levels are correct.
An update. The display is not broken!
I re-seated the connector; which visually looked like it would sit perfectly. I was under the impression that it has been sitting still for months, so I really did not expect this to help.
Since the next step would indeed be probing these tiny traces, which is not something I can with the gear I have, I went ahead to just try whatever I could: different power supply, different cable, re-seating the connector.
The connector sits pretty good, so I’m quite surprised this helped…
Thanks for thinking along.
This sounds like the same issue I had, where a reseat of the connector resolved it. Maybe this should be added to the FAQs and/or the troubleshooting pages?
I’m not sure there is any way for the inky to detect that the screen is not connected correctly, I don’t think the screen feeds back anything that can be checked.
Yeah, if that’s possible I’d like to hear it. I’m not familiar with the lower level workings. I was expecting some sort of error but instead it just returns quickly. Maybe thats enough? Start and read a timer and if its <1 second its a red flag.
If it is not connected properly, how could it ever report something back?!
