Inky Frame Word Clock - BST modification
The Inky Frame word clock is excellent but doesn’t account for British Summer Time (or any other daylight saving time).
I have written a Medium article (here) in this topic:
For this post, here is my modified code for the word_clock.py program.
# New Code word_clock.py
import machine
import ntptime
# Length of time between updates in minutes.
UPDATE_INTERVAL = 15
graphics = None
rtc = machine.RTC()
time_string = None
words = ["it", "d", "is", "m", "about", "l", "half", "c", "quarter", "b", "to", "u", "past", "n", "one",
         "two", "three", "four", "five", "six", "eleven", "ten", "nine", "eight", "seven", "rm", "twelve", "rt", "O'Clock", "q"]
def approx_time(hours, minutes):
    nums = {0: "twelve", 1: "one", 2: "two",
            3: "three", 4: "four", 5: "five", 6: "six",
            7: "seven", 8: "eight", 9: "nine", 10: "ten",
            11: "eleven", 12: "twelve"}
    if hours == 12:
        hours = 0
    if minutes > 0 and minutes < 8:
        return "it is about " + nums[hours] + " O'Clock"
    elif minutes >= 8 and minutes < 23:
        return "it is about quarter past " + nums[hours]
    elif minutes >= 23 and minutes < 38:
        return "it is about half past " + nums[hours]
    elif minutes >= 38 and minutes < 53:
        return "it is about quarter to " + nums[hours + 1]
    else:
        return "it is about " + nums[hours + 1] + " O'Clock"
def is_bst(date_tuple):
    year, month, day, weekday, hour, minute, second, subseconds = date_tuple[:8]
    # BST starts on the last Sunday in March
    if month > 3 and month < 10:
        return True
    if month == 3:
        # Calculate the last Sunday in March
        last_sunday = 31 - (weekday if day > 24 else weekday + 7)
        return day > last_sunday
    if month == 10:
        # BST ends on the last Sunday in October
        return day <= last_sunday
    return False
def update():
    global time_string
    # grab the current time from the NTP server and update the Pico RTC
    try:
        ntptime.settime()
    except OSError:
        print("Unable to contact NTP server")
    # Get the current time from the RTC
    current_t = rtc.datetime()
    # Extract the hour and minute
    hour = current_t[4]  # Hours since midnight [0, 23]
    minute = current_t[5]  # Minutes after the hour [0, 59]
    # Manually check if BST should apply
    if is_bst(current_t):
        hour += 1
        # Handle hour overflow (24-hour format)
        if hour == 24:
            hour = 0
    # Calculate the approximate time in words
    time_string = approx_time(hour - 12 if hour > 12 else hour, minute)
    # Splits the string into an array of words for displaying later
    time_string = time_string.split()
    print(time_string)
def draw():
    global time_string
    graphics.set_font("bitmap8")
    WIDTH, HEIGHT = graphics.get_bounds()
    # Clear the screen
    graphics.set_pen(1)
    graphics.clear()
    graphics.set_pen(6)
    # Values for the layout and spacing
    if WIDTH == 640:  # Inky Frame 4.0"
        default_x = 5
        x = default_x
        y = 10
        line_space = 70
        letter_space = 40
    elif WIDTH == 800:
        default_x = 5
        x = default_x
        y = 70
        line_space = 60
        letter_space = 50
    else:  # Inky Frame 5.7"
        default_x = 20
        x = default_x
        y = 40
        line_space = 65
        letter_space = 35
    scale = 5
    spacing = 2
    for word in words:
        if word in time_string:
            graphics.set_pen(0)
        else:
            graphics.set_pen(graphics.create_pen(220, 220, 220))
        for letter in word:
            text_length = graphics.measure_text(letter, scale, spacing)
            if not x + text_length <= WIDTH:
                y += line_space
                x = default_x
            graphics.text(letter.upper(), x, y, 640, scale=scale, spacing=spacing)
            x += letter_space
    graphics.update()
I hope this helps.
Instead of calculating the daylight saving time period manually, it would be easier to query http://worldtimeapi.org/api/ip directly instead of ntp. The problem with your approach: it is not universally valid: British DST-rules are British DST-rules, but not universally valid.
The output of worldtimeapi.org is an easy to parse JSON-structure:
  "utc_offset": "+02:00",
  "timezone": "Europe/Berlin",
  "day_of_week": 5,
  "day_of_year": 222,
  "datetime": "2024-08-09T15:46:01.818053+02:00",
  "utc_datetime": "2024-08-09T13:46:01.818053+00:00",
  "unixtime": 1723211161,
  "raw_offset": 3600,
  "week_number": 32,
  "dst": true,
  "abbreviation": "CEST",
  "dst_offset": 3600,
  "dst_from": "2024-03-31T01:00:00+00:00",
  "dst_until": "2024-10-27T01:00:00+00:00",
  "client_ip": "xx.xx.xx.xx"
Instead of querying by IP, you can also pass a timezone to the API.
I came across this thread while looking for sample Micropython code to handle British Summer Time when not connected to the internet.
I would like to offer an alternative algorithm for calculating the last Sunday in March and October:
last_sunday = 25 + (day + 9 - weekday)%7
as I didn’t understand the original version.
Although this is not universally valid, it should work in the EU as well as the UK, as I believe we use the same DST rules.
Here is a little program to check the results:
  # year, month, day, weekday, hour, minute, second, subseconds = date_tuple[:8]
    year, month, day, hour, minute, second, weekday, yearday = date_tuple[:8]
    # BST starts at 01:00 GMT on the last Sunday in March
    # and ends at 02:00 BST on the last Sunday in October
    if 3 < month < 10:
        return True
    if month == 3:
        # Calculate the last Sunday (weekday 6) in March
      # last_sunday = 31 - (weekday if day > 24 else weekday + 7)
      # return day > last_sunday
        return day >= last_sunday
    if month == 10:
      # return day <= last_sunday
        return day < last_sunday
    return False
# Main program...
for year in range(2015, 2025):
    for month in (3, 10):
        print("")
        for day in range(32):
            date_time = time.gmtime(time.mktime((year, month, day, 0, 0, 0, 0, 0, 0)))
            print(date_time, is_bst(date_time))
I used time.gmtime and time.mktime to provide the appropriate weekday for each date.
Note that gmtime and mktime use a slightly different date-time format to machine.RTC.
