Following the tutorial https://learn.pimoroni.com/tutorial/sandyj/getting-started-with-inky-phat
On Raspian GNU/Linux 8
Cloned the GitHub repo https://github.com/pimoroni/inky
The name-badge.py example gives me
ImportError: This library requires the smbus2 module
If I do the recommended sudo pip install smbus2 I get
ImportError: No module named _internal.cli.main
Tried sudo pip3 install smbus2 and I got
… error in smbus2 setup command: ‘extras_require’ must be a dictionary
Also tried sudo pip3 install smbus2==‘0.3.0’ and I got the same error.
Any ideas?
Also tried the direct curl install
curl https://get.pimoroni.com/inky | bash
for which I had to add the -k flag since the https certificate has expired.
Get the following errors for each package:
File "/usr/local/bin/pip2", line 7, in <module>
from pip._internal.cli.main import main
Unable to install RPi.GPIO for python2!
File "/usr/local/bin/pip3", line 7, in <module>
ImportError: No module named pip_internal
Unable to install RPi.GPIO for python3!
Looks like my pip is corrupted, so I tried reinstalling pip
sudo apt purge python-pip python3-pip -y
sudo apt install python-pip python3-pip -y
and I get the same errors. Any ideas?
Also thought this might help, to get pip to stop complaining
python, pip
This seemed to work
sudo easy_install pip
Then tried the curl with a bit more success, seemed to run through and install stuff (took ages)
Tried to run the name badge example again and it still complained about smbus2
sudo pip install smbu2
and get
error in smbus2 setup command: 'extras_require' must be a dictionary...
Honestly, python version/package management could easily drive you insane…
Would really really appreciate some help on this, I’ve got a pHAT and a wHAT just waiting to go!
SOLVED
For anyone else that ends up here, this is what eventually worked for me:
Install the latest Rasbian. Install script then ran through successfully.
Turn on i2c via raspi-config and reboot
Make sure the Inky pHAT is pushed down really firmly
Hoorah! Now I can make something cool!
