I have been using the ledshim with raspberry pi os 32 bit without any issues.
I upgraded to the newest raspberry pi os 64bit using the l;latest raspberry pi imager.
When i try to run the install script for ledshim
I get the following error, appreciate if someone can help.
pi@raspberrypi:~ $ sudo curl https://get.pimoroni.com/ledshim | bash
** % Total % Received % Xferd Average Speed Time Time Time Current**
** Dload Upload Total Spent Left Speed**
100 38790 100 38790 0 0 206k 0 --:–:-- --:–:-- --:–:-- 206k
This script will install everything needed to use
LED SHIM
Always be careful when running scripts and commands copied
from the internet. Ensure they are from a trusted source.
If you want to see what this script does before running it,
you should run: 'curl https://get.pimoroni.com/ledshim’
This hardware is not supported, sorry!
Config files have been left untouched
