PIANO HAT and Scratch
Does the PIANO HAT work with Scratch? Is there documentation that indicates which GPIO pin values to set/read so it can be used with ScratchGPIO?
Thank you!
Sean
There’s no ScratchGPIO support yet that I’m aware of. It also doesn’t use GPIO directly ( the touch sensing is via little chips that talk I2C ) so it couldn’t be used by set/reading GPIO values.
I’ll see what I can do about getting it supported.
Brilliant, thank you!
