Pimoroni Explorer: problem setup C/C++ project
Hi! I’m trying to get C/C++ code working on the Pimoroni Explorer board, but I haven’t had any success so far.
MicroPython works perfectly, so the hardware seems fine. But for my project I need C/C++. I’ve tried multiple setups: using pico-sdk, pimoroni-pico, pico-examples, Arduino IDE, a Debug Probe, and going through available documentation, but none of it worked.
It seems that most tutorials and projects are targeted specifically at Pico boards, and Explorer (with RP2350 chip) isn’t officially listed. In some cases CMake asks to specify PICO_BOARD, but “explorer” is not among the available options. I tried building with all RP2350-based configurations I could find, but nothing succeeded.
Has anyone managed to get a working C/C++ setup for Pimoroni Explorer? Any pointers, minimal example, or configuration help would be greatly appreciated!
I was having trouble getting a basic c++ project to display on the included display of the explorer. I was finally able to get it to work by adding the compile definition PICO_PIO_USE_GPIO_BASE=1 to my CMakeLists file.
I think this is because the built in display uses GPIO 32-39 for the data bus but to access those pins with the generated PIO header could not access these pins. Setting PICO_PIO_USE_GPIO_BASE=1 allows it to access those pins. The full change to the CMakeLists.txt file was adding
add_compile_definitions(PICO_PIO_USE_GPIO_BASE=1)
Some more information on the compile flag can be found in here
https://www.raspberrypi.com/documentation/pico-sdk/hardware.html
Thanks for reply @matt1!
Unfortunately this also does not work for me. Maybe I am trying wrongly.
Have you used this device? https://shop.pimoroni.com/products/explorer
And which repositary do you run? Pico-sdk, pimoroni-pico or something else?
Also which board definition do you use? I have suspicion that none of them is for my board and that is reason why it goes bad.
It would be huge help if you send me some minimal functional example, if you have one. Thanks!
Yes, that looks like the device I am using.
Using the VS code extension GitHub - raspberrypi/pico-vscode: The official VS Code extension for Raspberry Pi Pico development. It includes several features to simplify project creation and deployment. I create a basic c++ project. I then add GitHub - pimoroni/pimoroni-pico: Libraries and examples to support Pimoroni Pico add-ons in C++ and MicroPython. as a submodule under libs/pimoroni-pico from the base of my new project (If you do it this way you may want to comment out the last line of the pimoroni-pico CMakeLists file to not build all the examples). Once I have that I modify my projects CMakeLists file and main.cpp file to look something like this.
# Generated Cmake Pico project file
cmake_minimum_required(VERSION 3.13)
set(CMAKE_C_STANDARD 11)
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_EXPORT_COMPILE_COMMANDS ON)
# Initialise pico_sdk from installed location
# (note this can come from environment, CMake cache etc)
# == DO NOT EDIT THE FOLLOWING LINES for the Raspberry Pi Pico VS Code Extension to work ==
if(WIN32)
    set(USERHOME $ENV{USERPROFILE})
else()
    set(USERHOME $ENV{HOME})
endif()
set(sdkVersion 2.2.0)
set(toolchainVersion 14_2_Rel1)
set(picotoolVersion 2.2.0-a4)
set(picoVscode ${USERHOME}/.pico-sdk/cmake/pico-vscode.cmake)
if (EXISTS ${picoVscode})
    include(${picoVscode})
endif()
set(PICO_BOARD pico2 CACHE STRING "Board type")
# Pull in Raspberry Pi Pico SDK (must be before project)
include(pico_sdk_import.cmake)
project(example C CXX ASM)
# Initialise the Raspberry Pi Pico SDK
pico_sdk_init()
# Enable PIO support for the 5th bit of GPIO pins
add_executable(example main.cpp )
pico_set_program_name(example "example")
pico_set_program_version(example "0.1")
# Modify the below lines to enable/disable output over UART/USB
pico_enable_stdio_uart(example 0)
pico_enable_stdio_usb(example 1)
add_subdirectory(${CMAKE_CURRENT_LIST_DIR}/libs/pimoroni-pico)
target_link_directories(
    example
    PRIVATE
# Add the standard library to the build
target_link_libraries(
    example
    pico_stdlib
    pimoroni_bus
    pico_graphics
    st7789
target_include_directories(
    example
    PRIVATE
# Add the standard include files to the build
target_include_directories(example PRIVATE
pico_add_extra_outputs(example)
And the main.cpp file
#include "pico/stdlib.h"
#include "common/pimoroni_bus.hpp"
#include "drivers/st7789/st7789.hpp"
#include "libraries/pico_graphics/pico_graphics.hpp"
using namespace pimoroni;
#define DISPLAY_WIDTH 320
#define DISPLAY_HEIGHT 240
ParallelPins parallel_bus = {
    .cs = 27,
    .dc = 28,
    .wr_sck = 30,
    .rd_sck = 31,
    .d0 = 32,
    .bl = 26
ST7789 st7789(
    DISPLAY_WIDTH,
    DISPLAY_HEIGHT,
    ROTATE_0,
    parallel_bus
PicoGraphics_PenRGB565 graphics(
    st7789.width,
    st7789.height,
    nullptr
int main() {
    stdio_init_all();
    while (true) {
        graphics.set_pen(0, 0, 0);
        graphics.clear();
        graphics.set_pen(0, 120, 120);
        graphics.text("Hello world!", Point(20, 140), 300, 4);
        st7789.update(&graphics);
        sleep_ms(1000);
@matt1 huge thanks! This now finally works for me. ;-)
If someone reading this, still has problem running it, hit me up.
is there a way to use it in arduino ide ? there is a arduino ide package for rp2040 & rp2350 which contains a board for pimoroni explorer. The only thing i’m not sure about is if it’s for the old or new board. I currently have the new board i think the same ones as you guys.
I noticed adafruit had drivers for the display so i tried that display driver but could not get it to work. display does not turn on however the compilation of the uf2 works and when uploaded to explorer board i can serial responses so i’m guessing it should be possible to get this working under arduino ide as well right ?
edit: i checked some more this lib indeed has support for our pimoroni explorer for arduino ide arduino-pico/variants/pimoroni_explorer/pins_arduino.h at master · earlephilhower/arduino-pico · GitHub it linked to the shematics of the explorer. However i’ve got no luck trying to get the screen to work. The arduino gfx lib which supports parralel busses for raspberry pico uses other pins then this. I also tried adding a platform.local.txt with extra cpp flags to define what you had added in the cmake file but i’m not sure if it will be needed or if that would work at all. I’m able to turn on the backlight of the lcd but not draw graphics to it
i managed to get it working with arduino ide see the following link you’ll also need arduino-pico as it got a board setup for the pimoroni explorer rp2350 board
@joyrider3774 works like a charm! Thanks!
Anyone reading this: Read and decide which solution is better for you.
