PIR motion sensor always high
I have bought the PIR motion sensor: PIR motion sensor – Pimoroni
I have wired it up according to this tutorial: How to Interface a PIR Motion Sensor With Raspberry Pi GPIO | Raspberry Pi | Maker Pro
Here is my code:
import RPi.GPIO as GPIO
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(11, GPIO.IN) #Read output from PIR motion sensor
i = GPIO.input(11)
time.sleep(0.5)
if i==0: #When output from motion sensor is LOW
print(“No intruders”)
elif i==1: #When output from motion sensor is HIGH
print(“Intruder detected”)
However i is always 1, unless I unplug it and it goes to zero. I have tried turning the sensitivity and delay down, hiding the PIR in a box etc. Nothing works, always high.
I have also tried it on pins 7 and 3 and in .net code which works with another PIR I have. Still doesn’t work.
I have a PIR motion sensor attached to a pi zero which controls an addressable led strip. I tested your code on my setup and it works perfectly. Could this be a hardware problem with the PIR?
thanks for looking into this. That was my thought but I wanted to make sure I wasn’t doing something obviously wrong. Do you think I should return the item as defective?
Yes, that’s what I would do. As you’ve tested the PIR on different pins it seems reasonable that the fault is with the PIR.
For anyone else that has this problem. The actual problem is that the pins are not as described in the tutorial " How to Interface a PIR Motion Sensor With Raspberry Pi GPIO | Raspberry Pi | Maker Pro " but are reversed. The actual pins are described here: Raspberry Pi GPIO Sensing: Motion Detection– The Pi Hut
For anyone else that has this problem, the pins are not correct but are the reverse to those described in the tutorial. Follow this tutorial if you want things to work: Raspberry Pi GPIO Sensing: Motion Detection– The Pi Hut
