Hi
I have the Raspi Pirate Audio dual mic Microphone with LCD display, I followed the software instructions on set up on the Pimoroni site.
The python code ‘clip-recorder.py’ works fine when I manually run it and it works as expected, which is great 👍
However when I tried to get the microphone code to open on start/boot up it fails and my LCD display just shows vertical lines, I know therefore that my code is triggering something but not properly as I want it to.
I set up my start boot up code in the following way
Folder location was:
sudo nano /etc/rc.local
Added the following line before exit 0:
sudo /usr/bin/python3 /home/pi/pirate-audio/clip-recorder[/clip-recorder.py
I have tried using CRON as an alternative but get the same outcome, it triggers the LCD on start up but not correctly.
Any thoughts ?
