An update on my Volumio webradio, Display Hat Mini Audio3W Shim PirateAudio. Volumio version 3.233 PirateAudio version 0.006. Workswell, but quite painful to get together from scratch. I was wandering , once I get the working image together , how can I make a copy of the complete image as a backup?,or clone the whole content might be the right word. I have tried win32diskimager but no success, maybe I do something wrong. Any help appreciated
Br carl
Win32DiskImager is the only PC program I’ve ever found that can make a full SD card backup. If you just backup one of the drives with it, it will back up everything.
On Linux you can use the dd command to do it (and there is PiShrink which can be used to compact the image), but that is a little more complicated as it’s command line. But it can be done on a Pi with a RaspiOS SD card and your Volumio card also plugged in via a USB adaptor. Just make sure you backup the correct drive…
