Plasma 2350
Sorry for the stupid question.
I’ve installed the .uf2 for my plasma 2350 from here:
I was able to install Thonny and click on the bottom right hand corner of to select ‘MicroPython (Raspberry Pi Pico) - /dev/ttyACM0)’. There is also an option for - ‘MicroPython (RP2040) - /dev/ttyACM0)’
I can run the examples and they work well but how do I save the code onto the board and get it to run when I plug it into a USB-C plug?
I tried saving the file onto the board as code.py but this didn’t seem to work.
I’m running Ubuntu on the connected PC.
You need to save your code to your Pico as main.py if you want it to run as default :)
