Presto Vector shape filled
Hi there,
i am playing around with my new Presto.
When using the vector engine: circles, reguler, star, rectangle can be drawed filled or just bordered. Only the “path” is always filled… Is this a bug or a feature?!
Wishes from Germany,
Rallo
You can pass in the stroke argument to draw just the borders.
For example a box with slightly rounded corners and 2 pixel border:
Polygon().rectangle(20, 20, 20, 20, (4, 4, 4, 4), stroke=2)
Should work with circle and other shapes too.
yes, you are right.
I can draw vector polygons like rectangle, circles, regular, arc and star in a bordered look, when i use “stroke=nnn”. Unfortunately there seems to be no possibility to create a custom polygon with multiple path() and “stroke=nnn”. I am searching for a way to draw polygons like this:
So i need to build an own function, which draws lines with display.line()?
Greetings from Muenster,
Ralf
