Hello,
I realize it’s a long shot,but maybe someone has an idea. Pico W with a Display Pack 2 and an images stored on a micro sd ( adapter connected to SP0).
The issue is that the images load a bit offset to the left and with each change they move further to the left. Images have the proper size and resolution. Loaded Pimoroni flavored micro python,latest version but also tried with previous versions. Same behavior.
I am running out of ideas and any help would be appreciated.
Here is my code :
import picodisplay
from picodisplay import Picodisplay, DISPLAY_PICO_DISPLAY_2 as display
import picographicsfrom machine import Pin, SPIimport jpegdecimport sdcardimport osimport randomimport timefrom pimoroni import Buttonfrom pimoroni import RGBLEDimport gcimport uos
set up the display . These are copied from default Image Pack2 examples
#display = picodisplay.Picodisplay(display=picodisplay.DISPLAY_PICO_DISPLAY_2, rotate=0)display = picographics.PicoGraphics(display=picographics.DISPLAY_PICO_DISPLAY_2, rotate=0)display.set_backlight(1.0)
Set up the display
display = Picodisplay(DISPLAY)
#display = (display)
#WIDTH = 320#HEIGHT = 240
Setup buttons
button_a = Button(12)button_b = Button(13)button_x = Button(14)button_y = Button(15)
led = RGBLED(6, 7, 8) # Physical hardware pins connections for RGB LED
From CPython Lib/colorsys.py . Set this for Rainbow LED
def hsv_to_rgb(h, s, v):if s == 0.0:return v, v, vi = int(h * 6.0)f = (h * 6.0) - ip = v * (1.0 - s)q = v * (1.0 - s * f)t = v * (1.0 - s * (1.0 - f))i = i % 6if i == 0:return v, t, pif i == 1:return q, v, pif i == 2:return p, v, tif i == 3:return p, q, vif i == 4:return t, p, vif i == 5:return v, p, qh = 0
Set up the SD card
sd_spi = SPI(0, sck=Pin(18, Pin.OUT), mosi=Pin(19, Pin.OUT), miso=Pin(16, Pin.OUT))sd = sdcard.SDCard(sd_spi, Pin(22))os.mount(sd, “/sd”)
Create a new JPEG decoder
j = jpegdec.JPEG(display)
Time between slides (in seconds)
IMAGE_PAUSE = 0.50 * 60 # 5 minutes between slides
def clear_screen():“”“Clear the screen with black”“”display.set_pen(display.create_pen(0, 0, 0))display.clear()display.update()
def display_image(filename):“”“Display a JPEG image on the screen”“”try:clear_screen() # Clear screen before displaying new imagej.open_file(filename)j.decode(0, 0, jpegdec.JPEG_SCALE_FULL)display.update()print(f"Displayed: {filename}“)except Exception as e:print(f"Error displaying {filename}: {e}”)# Display error messagedisplay.set_pen(display.create_pen(255, 0, 0))display.text(f"Error loading image", 10, 10, 240, 2)display.update()
Get list of JPEG files on SD card.older micropython versions. endswith not supported
files = [f for f in os.listdir(“/sd”) if f.lower().endswith((“.jpg”, “.jpeg”))]
Display intro image (assuming “intro.jpg” exists on SD card)
intro_image = “/sd/intro.jpg”try:display_image(intro_image)except:# If no intro image, display first imagedisplay_image(“/sd/” + files[0])
Wait for any button press to start slideshow
print(“Waiting for button press to start slideshow…”)while True:if button_a.is_pressed or button_b.is_pressed or button_x.is_pressed or button_y.is_pressed:breaktime.sleep(0.1)
Initialize slideshow variables
current_index = random.randrange(len(files))last_change_time = time.time()last_button_press = time.time()
Main slideshow loop
h += 1 # this is needed for Rainbow LED
r, g, b = [int(255 * c) for c in hsv_to_rgb(h / 360.0, 1.0, 1.0)] # rainbow magic
led.set_rgb(r, g, b) # Set LED to a converted HSV value
now = time.time()
# Check for button presses with debounce
if (button_a.is_pressed or button_b.is_pressed) and (now - last_button_press > 0.5):
button_b_led = led.set_rgb(0, 255, 0)
last_button_press = now
if button_a.is_pressed: # Previous image
current_index = (current_index - 1) % len(files)
print("Button A pressed - previous image")
display.update()
elif button_b.is_pressed: # Next image
current_index = (current_index + 1) % len(files)
button_x_led = led.set_rgb(0, 0, 255)
print("Button B pressed - next image")
# Display the selected image
display_image("/sd/" + files[current_index])
last_change_time = now
# Automatic slideshow advance
elif now - last_change_time >= IMAGE_PAUSE:
time.sleep(0.1) # Small delay to reduce CPU usage
Thank you.
