Got my new Phat today. Soldered just fine. Stuck it on the back of a Pi3.
Ran test.sh and I have to literally place my ear on the speaker to hear it.
(check level at alsamixer - not the issue)
ALSO,
the sound is VERY SLOW - I thought maybe it was some funky hip hop - but its SLOW speed making the voice LOW frequency.
Tried a Youtube video - same thing. Like 1/2 speed or slower.
Vu meters work fine on test.sh and youtube.
Here’s output from test.sh
pi@HQ:~/Pimoroni/speakerphat/test $ ./test.sh
testing audio
speaker-test 1.0.28
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Using device: speaker-phat
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 2048 to 8192
Period size range from 1024 to 1024
Using max buffer size 8192
Periods = 4
was set period_size = 1024
was set buffer_size = 8192
0 - Front Left
1 - Front Right
Time per period = 5.696775
testing basic wav playback
Playing WAVE ‘./test.wav’ : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
testing text-to-speech
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
ALSA lib pcm_dmix.c:961:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
testing VU meter
Sure would like this to work.
I’ve read all the threads on the forum.
thx
jaymer…
