Hello,
I’m using the Adafruit Audio FX (2MB) with audio jack to trigger sounds. I’ve soldered it up, put it on a breadboard. It will only trigger one sound, then a red light appears and it won’t trigger anything else.
I originally attached it to my metal grass sculpture (the spring shapes attach to the ground so that the “grass” strands trigger a sound when they tap the spring shapes.) I’m using the example sounds. I power the board, can trigger one sound, and then the red led on the board turns on and I can’t trigger anything else. I tried removing the grass sculpture and just using the breadboard (and triggering a sound only when I connect a pin to the ground.) The same thing seems to happen.
Any ideas on what I can do?
