I would like to get my bot running. I have a Raspberry Pi 4, 8GB. The pi runs fine.
Trilobot Example: Print Distance
File “/home/jay/Pimoroni/trilobot/examples/./print_distance.py”, line 16, in
tbot = Trilobot()
File “/usr/local/lib/python3.9/dist-packages/trilobot/init.py”, line 134, in init
self.sn3218 = sn3218.SN3218()
File “/usr/local/lib/python3.9/dist-packages/sn3218/init.py”, line 34, in init
self.enable_leds(enable_mask)
File “/usr/local/lib/python3.9/dist-packages/sn3218/init.py”, line 63, in enable_leds
self.i2c.write_i2c_block_data(I2C_ADDRESS, CMD_ENABLE_LEDS, [
Exception ignored in: <function Trilobot.del at 0xf705b730>
File “/usr/local/lib/python3.9/dist-packages/trilobot/init.py”, line 155, in del
self.sn3218.disable()
AttributeError: ‘Trilobot’ object has no attribute ‘sn3218’
The above is the result of trying any of the examples. Except for the name of the example.
I have built the trilobot. I have the latest version Raspberry Pi OS. Here is the result of ‘uname -a’:
Linux telzey 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
Any help will be appreciated.
