I wish to switch off the VU meter and have tried deleting/ modifying the asound file with no luck. I even removed it from the directory and the display keeps working?
I am new to this so any helps or updates that will make this work would be gratefully received. Thanks Graham
Did you restart your Pi/audio software after deleting /etc/asound.conf?
You might also want to try: sudo systemctl restart pulseaudio
Thank you, yes i did a restart and tried the sudo script as you suggested with no luck.
Note: the asound.conf is not deleted its in another directory, is this ok?
That’s… bizarre!
Sure it’s actually moved from the directory and not copied? And not being shadowed by an ~/.asoundrc
file (a file named .asoundrc
in your home directory, normally /home/pi
Without the /etc/asound.conf
to tell ALSA to use the VU Meter plugin, there should be no VU at all!
The shadowing comment has my interest, please see attached pic. Am I looking in the right place? I’m not sure about “.” after ~/?
The GCV directory is where the asound.conf is.
What is .asoundrc? I have found this and moved it to a temp directory still no luck.
I hope this helps?
Very many thanks for your help
Graham
Oooh, looking at the screenshot it looks like you need to remove the /etc/asound.conf
actually installed to your system, ie: if you literally type:
sudo mv /etc/asound.conf /etc/asound.conf.bak
It should do the trick!
The files in the pivumeter directory are only the original versions- these are copied into the right place on your system during install.
Hi Phil,
Magic…that worked a treat. Very many thanks for all your help.
Kind regards
Graham
