TypeError: ST7789.display() missing 1 required positional argument: 'image'
I have a Pi Zero 2W with a 1.54" SPI Colour Square LCD (240x240) Breakout
and a Multi-Sensor Stick (BME280 + LTR559 + LSM6DS3)
With the smaller 0.96" SPI Colour LCD (160x80) Breakout I can run the
all-in-one-enviro-mini.py file from the virtual enviroment with out issue.
enviroplus-python/examples/all-in-one-enviro-mini.py at main · pimoroni/enviroplus-python · GitHub
Having trouble getting it to work with the larger LCD though?
kyrie@enviro:~ $ source ~/.virtualenvs/pimoroni/bin/activate
(pimoroni) kyrie@enviro:~ $ python enviro-st7789-mini.py
2025-10-25 09:09:53.586 INFO all-in-one.py - Displays readings from all of Enviro plus" sensors
Press Ctrl+C to exit!
2025-10-25 09:09:54.050 INFO temp: 13.1 °C
File “/home/kyrie/enviro-st7789-mini.py”, line 165, in
display_text(variables[mode], data, unit)
File “/home/kyrie/enviro-st7789-mini.py”, line 112, in display_text
ST7789.display(img)
TypeError: ST7789.display() missing 1 required positional argument: ‘image’
#!/usr/bin/env python3
import colorsys
import os
import sys
#import st7735
from st7789 import ST7789
# General
SPI_PORT = 0
SPI_CS = 1
SPI_DC = 9
#BACKLIGHT = 13
# Screen dimensions
WIDTH = 240
HEIGHT = 240
try:
    # Transitional fix for breaking change in LTR559
    from ltr559 import LTR559
    ltr559 = LTR559()
except ImportError:
    import ltr559
import logging
from subprocess import PIPE, Popen
from bme280 import BME280
from fonts.ttf import RobotoMedium as UserFont
from PIL import Image, ImageDraw, ImageFont
logging.basicConfig(
    format="%(asctime)s.%(msecs)03d %(levelname)-8s %(message)s",
    level=logging.INFO,
    datefmt="%Y-%m-%d %H:%M:%S")
logging.info("""all-in-one.py - Displays readings from all of Enviro plus" sensors
# BME280 temperature/pressure/humidity sensor
bme280 = BME280()
# Create ST7735 LCD display class
st7735 = st7735.ST7735(
    port=0,
    cs=1,
    dc="GPIO9",
    backlight="GPIO12",
    rotation=270,
    spi_speed_hz=10000000
# Initialize display
st7735.begin()
WIDTH = st7735.width
HEIGHT = st7735.height
display = ST7789(
    port=SPI_PORT,
    cs=SPI_CS,
    dc=SPI_DC,
    #backlight=BACKLIGHT,
    #width=WIDTH,
    #height=HEIGHT,
    rotation=180,
    spi_speed_hz=60 * 1000 * 1000,
# Set up canvas and font
img = Image.new("RGB", (WIDTH, HEIGHT), color=(0, 0, 0))
draw = ImageDraw.Draw(img)
path = os.path.dirname(os.path.realpath(__file__))
font_size = 20
font = ImageFont.truetype(UserFont, font_size)
message = ""
# The position of the top bar
top_pos = 25
# Displays data and text on the 0.96" LCD
def display_text(variable, data, unit):
    # Maintain length of list
    values[variable] = values[variable][1:] + [data]
    # Scale the values for the variable between 0 and 1
    vmin = min(values[variable])
    vmax = max(values[variable])
    colours = [(v - vmin + 1) / (vmax - vmin + 1) for v in values[variable]]
    # Format the variable name and value
    message = f"{variable[:4]}: {data:.1f} {unit}"
    logging.info(message)
    draw.rectangle((0, 0, WIDTH, HEIGHT), (255, 255, 255))
    for i in range(len(colours)):
        # Convert the values to colours from red to blue
        colour = (1.0 - colours[i]) * 0.6
        r, g, b = [int(x * 255.0) for x in colorsys.hsv_to_rgb(colour, 1.0, 1.0)]
        # Draw a 1-pixel wide rectangle of colour
        draw.rectangle((i, top_pos, i + 1, HEIGHT), (r, g, b))
        # Draw a line graph in black
        line_y = HEIGHT - (top_pos + (colours[i] * (HEIGHT - top_pos))) + top_pos
        draw.rectangle((i, line_y, i + 1, line_y + 1), (0, 0, 0))
    # Write the text at the top in black
    draw.text((0, 0), message, font=font, fill=(0, 0, 0))
    ST7789.display(img)
# Get the temperature of the CPU for compensation
def get_cpu_temperature():
    process = Popen(["vcgencmd", "measure_temp"], stdout=PIPE, universal_newlines=True)
    output, _error = process.communicate()
    return float(output[output.index("=") + 1:output.rindex("'")])
# Tuning factor for compensation. Decrease this number to adjust the
# temperature down, and increase to adjust up
factor = 2.25
cpu_temps = [get_cpu_temperature()] * 5
delay = 0.5  # Debounce the proximity tap
mode = 0  # The starting mode
last_page = 0
light = 1
# Create a values dict to store the data
variables = ["temperature",
             "pressure",
             "humidity",
             "light"]
values = {}
for v in variables:
    values[v] = [1] * WIDTH
# The main loop
try:
        proximity = ltr559.get_proximity()
        # If the proximity crosses the threshold, toggle the mode
        if proximity > 1500 and time.time() - last_page > delay:
            mode += 1
            mode %= len(variables)
            last_page = time.time()
        # One mode for each variable
        if mode == 0:
            # variable = "temperature"
            unit = "°C"
            cpu_temp = get_cpu_temperature()
            # Smooth out with some averaging to decrease jitter
            cpu_temps = cpu_temps[1:] + [cpu_temp]
            avg_cpu_temp = sum(cpu_temps) / float(len(cpu_temps))
            raw_temp = bme280.get_temperature()
            data = raw_temp - ((avg_cpu_temp - raw_temp) / factor)
        if mode == 1:
            # variable = "pressure"
            unit = "hPa"
            data = bme280.get_pressure()
        if mode == 2:
            # variable = "humidity"
            unit = "%"
            data = bme280.get_humidity()
        if mode == 3:
            # variable = "light"
            unit = "Lux"
            if proximity < 10:
                data = ltr559.get_lux()
            else:
                data = 1
# Exit cleanly
except KeyboardInterrupt:
    sys.exit(0)
By calling ST7789.display, it looks like you are calling the method on the class rather than the instance. In the linked example, it calls st7735.display - note the use of lower case - which refers to the instance of the ST7735 class.
In your code, your instance isn’t called st7735 or st7789 but display. So, maybe display.display would work.
I was also refering to this example,
st7789-python/examples/320x240.py at main · pimoroni/st7789-python · GitHub
which uses, from st7789 import ST7789
I think that example is out dated though? I’m going to have another go and just replace st7735 with st7789 or ST7789 and see what errors crop up.
Now working. It was a combination of clip and past errors. One example used display =, and the other stxxxx =. Plus I had the backlight turned off on my 1.3 inch LCD. It’s mounted to a proto board and has a backlight “off” switch, that I forgot about. That had me scratching my head when my code ran without error, but nothing displayed?
Anyway, your sujestion pointed me in the right direction, so many thanks’s. =)
import colorsys
import os
import sys
import st7789
try:
    ltr559 = LTR559()
except ImportError:
    import ltr559
import logging
    level=logging.INFO,
bme280 = BME280()
st7789 = st7789.ST7789(
    port=0,
    cs=0,
    dc="GPIO9",
    #backlight=19,
    rotation=90,
    spi_speed_hz=80 * 1000 * 1000,
    #spi_speed_hz=10000000
st7789.begin()
WIDTH = 240
HEIGHT = 240
font_size = 20
message = ""
top_pos = 25
    st7789.display(img)
factor = 2.25
last_page = 0
light = 1
             "pressure",
             "humidity",
             "light"]
values = {}
for v in variables:
# The main loop
try:
            mode += 1
        if mode == 0:
            unit = "°C"
        if mode == 1:
            unit = "hPa"
        if mode == 2:
            unit = "%"
        if mode == 3:
            unit = "Lux"
            if proximity < 10:
            else:
                data = 1
# Exit cleanly
    sys.exit(0)
