Created a repo for the pantilthat that uses multiprocessing.
You need to from the command line.
have no idea why the IDEL doesn’t like the shared memory code. It just doesn’t run without error.
ne The above works and its no problem.
Currently set to 1024x768 which is as large as you can go without swamping the pi to oblivion.
Trying changing to 800x600 and 640x480 and see how the shared memory really helps with performance especially latency.
To grab all the libs and setup
The real work was done at https://github.com/vmlaker/sherlock all credit should go there.
I have burnt out my face tracking curiosity and what we have is ropey but actually getting near something useful, if anyone fancies taking it a stage further, please do so.
