It looks like the example script raspicam.py is supposed to display what the camera detects on the Unicorn HAT HD. The only thing is that I can’t get it working. I ran a test on the camera and it seems to be working fine. When I run raspicam.py (just like any other example script), it pauses at:
Unicorn HAT HD: Raspberry Pi Camera Display
Show a 16x16 feed from your Raspberry Pi camera!
/usr/lib/python2.7/dist-packages/picamera/encoders.py:521: PiCameraAlphaStripping: using alpha-stripping to convert to non-alpha format; you may find the equivalent alpha format faster
"using alpha-stripping to convert to non-alpha "
/usr/lib/python2.7/dist-packages/picamera/encoders.py:544: PiCameraResolutionRounded: frame size rounded up from 16x16 to 32x16
width, height, fwidth, fheight)))
while displaying nothing on the Unicorn HAT HD, and then when I keyboard interrupt, It finishes off with:
File "raspicam.py", line 20, in <module>
camera.capture(stream, format='rgb', resize=(16, 16))
File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 1425, in capture
encoder.close()
File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 431, in close
self.stop()
File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 419, in stop
self._close_output()
File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 349, in _close_output
mo.close_stream(output, opened)
File "/usr/lib/python2.7/dist-packages/picamera/mmalobj.py", line 371, in close_stream
stream.flush()
File "/usr/lib/python2.7/dist-packages/picamera/array.py", line 238, in flush
self.array = bytes_to_rgb(self.getvalue(), self.size or self.camera.resolution)
File "/usr/lib/python2.7/dist-packages/picamera/array.py", line 127, in bytes_to_rgb
'Incorrect buffer length for resolution %dx%d' % (width, height))
picamera.exc.PiCameraValueError: Incorrect buffer length for resolution 16x16
Any thoughts on what I might be able to do to get this working? I’m thinking that the answer may be in here, but I’m trying to figure out how to incorporate it. Thanks!
