Unicorn HAT Mini Remote I/O error
Hi, I just purchased a Unicorn HAT Mini to go with a Raspberry Pi Zero WH. When I try to run the example Python scripts following the instructions here, I get a ‘No ADC detected’ error (see below). I have tried two different Pis and tested Bullseye and Bookworm. The installation script set do_spi and do_i2c to 0, so I think those are good (and I did restart after those changes). I’ve also tried as a user and root with the same results. Thanks for any help you can provide.
output.py
This Automation HAT Mini example toggles and displays the
status of the three 24V-tolerant digital outputs.
Press CTRL+C to exit.
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/automationhat/__init__.py", line 367, in setup
    chip_type = _ads1015.detect_chip_type()
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/ads1015/__init__.py", line 70, in wrapper
    return func(self, *args, **kwargs)
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/ads1015/__init__.py", line 248, in detect_chip_type
    self._ads1015.set("CONFIG", mode="single")
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/i2cdevice/__init__.py", line 215, in set
    self.read_register(register)
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/i2cdevice/__init__.py", line 183, in read_register
    self.values[register.name] = self._i2c_read(register.address, register.bit_width)
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/i2cdevice/__init__.py", line 288, in _i2c_read
    for x in self._i2c.read_i2c_block_data(self._i2c_address, register, bit_width // self._bit_width):
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/smbus2/smbus2.py", line 617, in read_i2c_block_data
    ioctl(self.fd, I2C_SMBUS, msg)
During handling of the above exception, another exception occurred:
  File "/home/pi/Pimoroni/automationhat/examples/hat-mini/output.py", line 77, in <module>
    automationhat.output[channel].write(state)
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/automationhat/__init__.py", line 238, in write
    self.setup()
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/automationhat/__init__.py", line 217, in setup
    setup()
  File "/home/pi/.virtualenvs/pimoroni/lib/python3.9/site-packages/automationhat/__init__.py", line 369, in setup
    raise RuntimeError("No ADC detected, check your connections")
RuntimeError: No ADC detected, check your connections
The link you posted is for the Automation Hat, not the Unicorn Mini?
You want to be following this.
Getting Started with Unicorn HAT Mini (pimoroni.com)
Wow, I can’t believe I missed that. Thank you so much for getting me on the right track! It worked great when I followed the right guide :-)
