Hi
I just got the Unicorn Hat and followed all the instructions in the setup. I can get the Unicorn Hat working when I run file (lets say rainbow_blinky.py) in terminal. But I can’t seem to stop the program in terminal (doesn’t bring back the command prompt). Any hints to do that?
and second
I can’t run any python scripts using idle following the instructions as I get this error
File “/home/pi/test.py”, line 5, in
import unicornhat as unicorn
File “/usr/local/lib/python3.5/dist-packages/unicornhat.py”, line 35, in
ws2812.begin()
File “/usr/local/lib/python3.5/dist-packages/rpi_ws281x/rpi_ws281x.py”, line 124, in begin
raise RuntimeError(‘ws2811_init failed with code {0} ({1})’.format(resp, str_resp))
RuntimeError: ws2811_init failed with code -5 (mmap() failed)
I have tried installing the unicorn-hat repo following someone else’s similar issue solved by someone. Same error again. I might be doing something wrong here.
Running a raspberry pi 2 B v1.1 with Jessie.
Regards
