Unicornhat install stops with: python-pip already installed
After following the initial instructions at link to learn.pimoroni.com/tutorial/raspberry-pi/keeping-your-raspberry-pi-updated I attempt the instructions at link to learn.pimoroni.com/tutorial/unicorn-hat/getting-started-with-unicorn-hat but install stops with the following and does not create the Pimoroni/unicornhat folder. How do I fix this? Thanks.
Checking install requirements…
Updating package indexes…
Hit link to archive.raspberrypi.org wheezy Release.gpg
Hit link to archive.raspberrypi.org wheezy/main armhf Packages
Hit link to raspbian.mirrors.lucidnetworks.net wheezy Release.gpg
Ign link to archive.raspberrypi.org wheezy/main Translation-en_GB
Hit link to raspbian.mirrors.lucidnetworks.net wheezy/main armhf Packages
Hit link to raspbian.mirrors.lucidnetworks.net wheezy/non-free armhf Packages
Ign link to raspbian.mirrors.lucidnetworks.net wheezy/main Translation-en_GB
Ign link to raspbian.mirrors.lucidnetworks.net wheezy/non-free Translation-en_GB
Reading package lists… Done
Installing UnicornHat requirements…
Checking for python-pip…
python-pip already installed.
PS would love to get involved with your crowdcube campaign but they recently switched from gocardless to stripe which will be a barrier for regular investors. If the campaign is slow you might like to ask them to switch back to gocardless.
PPS had to replace http with “link to” otherwise could not save.
Enjoy your day.
Regards,
Martyn
Hi - yes that scripts currently fails to do its job on Wheezy :(
Try:
sudo apt-get --force-yes --yes install python-dev python3-dev python-pip python3-pip
then re-run
curl -sS get.pimoroni.com/unicornhat | bash
that should work.
Oh! What’s the problem with Stripe vs Gocardless?
Stripe pulls money from your account (ie you authorise them to take whatever they want, when they want, for whatever reason they want), Gocardless is an agreement for a specific amount for a specific purpose only.
Excellent! Thank you @RogueM all working now.
