WeatherHat: Failed to add edge protection
I have just received the Weather Hat from Pimoroni.
I have been battling to get the weather.py or any other code to run. I have started with a fresh install and tried on various Raspberry Pi 3’s. I keep getting the following error:
RuntimeError: Failed to add edge detection.
I am starting to think that the Hat is faulty, any help please?
Are you using Pi OS Lite? If so, you might need to sudo apt install python3-pip git libatlas-base-dev to grab the extra dependencies.
(and then possibly run our installer again - I can’t remember if that was necessary)
Hi
Nope not using Pi OS Lite, using the full version.
Hmm, did you get any errors when you ran the installer?
None at all. I have done a few fresh installs, each time the same?
I am having the same issue. Cant seem to find assistance anyhwere
