I got my mono pirate radio (RPi Zero W + PhatBeat) and installed it. Everything installed fine but Mopidy seems t crash frequently :
pi@raspberrypi:~ $ sudo service mopidy status
mopidy.service - Mopidy music server
Loaded: loaded (/lib/systemd/system/mopidy.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Tue 2017-09-19 08:50:17 CEST; 1min 0s ago
Process: 24975 ExecStart=/usr/bin/mopidy --config /usr/share/mopidy/conf.d:/etc/mopidy/mopidy.conf (code=killed, signal=SEGV)
Process: 24970 ExecStartPre=/bin/chown mopidy:audio /var/cache/mopidy (code=exited, status=0/SUCCESS)
Process: 24967 ExecStartPre=/bin/mkdir -p /var/cache/mopidy (code=exited, status=0/SUCCESS)
Main PID: 24975 (code=killed, signal=SEGV)
Sep 19 07:48:33 raspberrypi mopidy[24975]: INFO New MPD connection from [::ffff:192.168.1.56]:57044
Sep 19 07:48:44 raspberrypi mopidy[24975]: INFO New MPD connection from [::ffff:192.168.1.56]:57050
Sep 19 07:48:55 raspberrypi mopidy[24975]: INFO New MPD connection from [::ffff:192.168.1.56]:57056
Sep 19 07:49:06 raspberrypi mopidy[24975]: INFO New MPD connection from [::ffff:192.168.1.56]:57076
Sep 19 08:28:29 raspberrypi mopidy[24975]: INFO Logged in to Spotify in online mode
Sep 19 08:49:15 raspberrypi mopidy[24975]: Using device: phat-beat
Sep 19 08:49:15 raspberrypi mopidy[24975]: sh: 1: festival: not found
Sep 19 08:50:17 raspberrypi systemd[1]: mopidy.service: Main process exited, code=killed, status=11/SEGV
Sep 19 08:50:17 raspberrypi systemd[1]: mopidy.service: Unit entered failed state.
Any idea where to look further to debug?
