Hi, I am having trouble getting the twitter code to work for the Scrollphathd,
I have set up a #tag for it to track
(unsure if I should have removed the # in the " keyword = ‘#3Dprinting’ " but the result is the same either way)
and input my various keys and tokens but when I set the code running I only get a few boxes and dots scrolling across my screen and no text. I have tried this from scratch many times and everyone else seems to be having no problems so I understand it must be something I am doing wrong.
just to let you know I have successfully got the wildfire and swirl to work along with scrolling test I input so the hardware seems to be fine.
I would appreciate any help as I would like to get my bot scrolling all my notifications but need to get this working before I try bending it to my purposes.
that’s working now. thanks :-)
now I need to figure out how to only nshow my notifications instead of the worlds tweets with the keyword. :-)
but I can try and figure that out now from this starting point.
thanks
I’m such a noob, I eventually go my script working. But, with a standard scrollphathd install… what command could I have run to download the new version of the script via git? I would like to pull all the examples anyway, there are some on the git that are not in my local install when I installed it via the Pimoroni Dashboard.
