Can someone help me figure out how to get the unicorn hat software compiled and running on a RPi2 with Arch Linux?
I believe that I have all needed prerequisites installed. When I try to build, I get this error:
root@alarmpi ..n/unicorn-hat-master/python/rpi-ws281x # make
sudo rm -rf build
sudo ./setup.py build
running build
running build_py
Compiling ws281x library...
creating build
creating build/lib.linux-armv7l-3.4
copying neopixel.py -> build/lib.linux-armv7l-3.4
running build_ext
building '_rpi_ws281x' extension
creating build/temp.linux-armv7l-3.4
gcc -pthread -Wno-unused-result -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -march=armv7-a -mfloat-abi=hard -mfpu=vfpv3-d16 -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC -Ilib/ -I/usr/include/python3.4m -c rpi_ws281x_wrap.c -o build/temp.linux-armv7l-3.4/rpi_ws281x_wrap.o
rpi_ws281x_wrap.c: In function 'PyInit__rpi_ws281x':
rpi_ws281x_wrap.c:4638:21: warning: variable 'md' set but not used [-Wunused-but-set-variable]
PyObject *m, *d, *md;
gcc -pthread -shared -Wl,-O1,--sort-common,--as-needed,-z,relro build/temp.linux-armv7l-3.4/rpi_ws281x_wrap.o -Llib/ -L/usr/lib -lws2811 -lpython3.4m -o build/lib.linux-armv7l-3.4/_rpi_ws281x.cpython-34m.so
/usr/bin/ld: lib//libws2811.a(ws2811.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
lib//libws2811.a: error adding symbols: Bad value
collect2: error: ld returned 1 exit status
error: command 'gcc' failed with exit status 1
Makefile:5: recipe for target 'build' failed
