Hello,
For the lazy ones | tl;dr:
UNICORN HAT NOT WORKING ON ARCH LINUX ARM SCROLL DOWN TO SEE IMPORT ERROR MESSAGE!
I wanted to use my Unicorn Hat (UH) shield with Arch Linux ARM (ALARM) on my Raspberry Pi 2 (RP2).
I’ve cloned the GIT repo yesterday morning (15.3.) and installed everything in the …/python folder via PIP into a virtualenv. the unicornd daemon was installed via sudo make install arch-linux (although I’m really not happy using make install for anything as it tends to just make everything a mess) and then enabled at boot via systemctl. ALARM is also up to date. Bleeding edge, the way Linux is supposed to be!
If I now start any of the provided example scripts e. g. sudo ./demo.py nothing happens and it’s not ctrl-C stopable. I read that some people hat similar problems running the UH “package” on ALARM but fixed it by downgrading gcc or editing some Makefile’s - however, according to the pull request history of GitHub all the suggested/successful solutions to these problems were already merged. Except for one issue (#35) stating that rpi-ws281x is broken in the newest ALARM, which was untouched since January. Someone commented that the daemon occassionally throws DMA errors but I haven’t noticed any (or I’m looking at the wrong place, also possible).
When I open a python console (remember, virtual env!) and try ‘’‘import unicornhat as uh’’’ I get this:
Failed to open /dev/vcio, trying old method.
Failed to create mailbox device /dev/mailbox-598: Permission denied
File "<stdin>", line 1, in <module>
File
"/home/norphi/Projects/unicorn-hat/python/UnicornHat/unicornhat.py",
line 14, in <module>
ws2812.begin()
File
"/home/norphi/Projects/bioreactor_building/.env/lib/python3.5/site-packages/neopixel.py",
line 107, in begin
raise RuntimeError('ws2811_init failed with code {0}'.format(resp))
RuntimeError: ws2811_init failed with code -1
Permission denied could be a hint but I don’t even get why /dev/mail… So this isn’t really helping me. Anyone an Idea? Is it really the same issue as #35? Something else?
As you can see from my path …/bioreactor_building/… I’m up to no good again. Help a mad scientist, win an ego boost!
Also someone explain me how to highlight inline code in markdown, please, as everything I tried wasn’t working.
The funny part: Actually I just need Python 3.5.1 on my RP2 but installing anything that isn’t obsolete by months on a Debian based system seems to be just not possible at all. I ended up rendering my Rasbian unbootable. Still no idea how that did happen…
Greetings,
NorPhi
