Hello gurus,
I don’t think this qualifies as a support post as I don’t really need too many specifics. I could use your ideas! 😻
End goal: I want to photograph and clean up antique stereo photographs via a Raspberry Pi 5, then load them to a set of Pico 2.8" displays to check the stereo quality in a low res stereo viewer (and for fun because it’s fun).
I was thinking I could* stream images to these display Picos via serial comms via a Python script on a Pi 5 since they will be connected via USB. The question then is, do I send over jpeg or png binary data to save as a file then show (I saw a couple of examples for loading images), or do I just stream pixel data somehow and stream to the display as the data arrives directly?
Secondly, will I run into issues while trying to stream to two serial ports/devices? Maybe they need to say hello first and say “I’m screen 2” for example? For speed reasons, I’m thinking a Pico per screen will be best. My brain is a bit mangled in regards of how to address and talk to these devices via serial (digging more today).
So far, I’ve been able to write to the display pixels directly with noise just to get things figured out:
# Pretend we are streaming in pixels from serial (not happening yet) and write to all display pixels.
import machine
import random
from pimoroni import RGBLED
from picographics import PicoGraphics, DISPLAY_PICO_DISPLAY_2
# set up the display and drawing constants
display = PicoGraphics(display=DISPLAY_PICO_DISPLAY_2, rotate=90)
# set the display backlight to 50%
display.set_backlight(0.5)
led = RGBLED(26, 27, 28)
def draw_loading_message():
display.set_pen(WHITE)
display.text("Loading...", 60, 150, 0, 3)
def draw_noise_pixel(x, y):
color = display.create_pen(random.randint(0, 255), random.randint(0, 255), random.randint(0, 255))
display.set_pen(color)
display.pixel(x, y)
def draw_noise_row(y):
x = 0
while x < WIDTH:
x = x + 1
def draw_noise_image():
y = 0
while y < HEIGHT:
draw_noise_row(y)
y = y + 1
# draw not on every row update (full update takes 3.5 secs or so, this slightly slower yet more fun)
if y % 4 == 0:
display.update()
#display.update()
# init "loading"
display.set_pen(BLACK)
display.clear()
led.set_rgb(100, 30, 0)
# draw image (pretend we're streaming in data and drawing it as it comes in)
draw_noise_image()
# done "loading"
led.set_rgb(0, 100, 0)
# enjoy image until a new image is available... after a delay for now
time.sleep(5)
It takes a short while to show the images (3-4 seconds). I’m ok with that. I haven’t tested loading image files yet. Perhaps it could be faster.
What are your thoughts on streaming full-display 240x320 images to the Pico for 2.8" display use?
Thanks for taking a look in advance! 😻
update: I’m drafting more here (untested, need to get out of Windows WSL and on a Pi shortly…)
