Hi, I am trying to set up a RPi with the 3w amp. I installed full RasPian and then ran the install script.
Everything is as it should be - up to the instructions to edit the mopidy config file to add the file path for the music files to the [local] section.
There is no [local] section in my config file.
I found an instruction to add various lines to the config file but these various lines (the ones to be added) are in fact all that my config file is made up from, there are no other lines. It is as if the original config file has been overwritten by the new lines - rather than having them added to it.
I have tried to simply add the line to redirect but to no avail.
So, to sum up… The display is working, telling me where to look for Iris. Iris is working but pointing to the wrong place for my files.
(In fact, once up and running, I would like to point it to a usb stick for my files).
Is there a standard config file that I can ‘find’?
Perhaps I’m trying to edit the wrong config file? (/etc/mopidy/mopidy.conf)
Any help for a struggling newbie gratefully received!
