Adafruit Flora - LCD Display
Hi
I recently puchased an Adafruit Flora from you and would like to know if there is an LCD display that can be used with it. I’m looking to display just a few digits as an indication of a cyclist’s speed.
Many thanks
You should look for i2c LCDs, this is a good one if you need only 4 digits (not strictly an LCD though): https://shop.pimoroni.com/products/adafruit-0-56-4-digit-7-segment-display-w-i2c-backpack or you could use the alphanumeric version: https://shop.pimoroni.com/products/quad-alphanumeric-display-0-54-digits-w-i2c-backpack
These are good, bit very, very tiny: https://shop.pimoroni.com/products/adafruit-monochrome-128x32-i2c-oled-graphic-display
I’m guessing it should be reasonably bold, clear and daylight viewable?
Thanks … the https://shop.pimoroni.com/products/adafruit-0-56-4-digit-7-segment-display-w-i2c-backpack looks suitable. Couple of questions though:
The description states that a 5v supply is required but, as far as I understand it, the Flora produces 3v … is this sufficient?
Is the backback pre-soldered? My soldering skills are not good ;)
Thanks again
Unfortunately it’s not pre-soldered, but the Flora does include a 5V output pin on its SPI header which is documented here: https://learn.adafruit.com/getting-started-with-flora/flora-pinout-diagram
The i2c backpack datasheet claims 3.3v logic levels are out of spec- IE: a “HIGH” is 0.7 VDD (ie: 3.4v) and a “LOW” is 0-0.3 VDD (ie: 1.5v). Anything between 1.5v and 3.4v is technically undefined behaviour, but in my experience tends to work fine!
