I’m trying to follow the Pimoroni getting started guide but am having trouble getting anything to work.
When I try to run drums.py I get the following errors:
Blockquote Explorer HAT Pro detected…
File “/home/pi/Pimoroni/explorerhat/examples/drums.py”, line 11, in
import explorerhat
File “/usr/lib/python3/dist-packages/explorerhat/init.py”, line 756, in
touch._add(one=CapTouchInput(4, 1))
File “/usr/lib/python3/dist-packages/explorerhat/init.py”, line 595, in init
_cap1208.on(channel=self.channel, event=event, handler=self._handle_state)
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 386, in on
self.start_watching()
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 400, in start_watching
self.async_poll.start()
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 208, in start
if self.isAlive() == False:
AttributeError: ‘AsyncWorker’ object has no attribute ‘isAlive’
Explorer HAT exiting cleanly, please wait…
Stopping flashy things…
Error in atexit._run_exitfuncs:
File “/usr/lib/python3/dist-packages/explorerhat/init.py”, line 689, in explorerhat_exit
light.stop_pulse()
File “/usr/lib/python3/dist-packages/explorerhat/pins.py”, line 92, in handler
return self._do(name, *args, **kwargs)
File “/usr/lib/python3/dist-packages/explorerhat/pins.py”, line 111, in _do
_results[node] = handler(*args, **kwargs)
File “/usr/lib/python3/dist-packages/explorerhat/init.py”, line 480, in stop_pulse
self.pulser.stop()
File “/usr/lib/python3/dist-packages/explorerhat/pins.py”, line 20, in stop
if self.isAlive():
AttributeError: ‘Pulse’ object has no attribute ‘isAlive’
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 409, in stop_watching
self.async_poll.stop()
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 213, in stop
if self.isAlive() == True:
Exception ignored in: <function Cap1xxx.del at 0xb32f34a8>
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 522, in del
Likewise when I try to run ‘import explorerhat’, I get the following:
File “”, line 1, in
I’m running a pretty fresh install of Raspbian that as far as I can tell is fully updated.
I did run the curl script once before, but I think because I2C was switched off it didn’t work. I then switched it on and ran it again, which seems to have got me closer but still not actually working.
I’m open to any suggestions on this, the Explorer Hat seems like a great way to start learning electronics in general - I’m really hoping my weekend can be spent building things rather than trouble shooting haha!
