Hi there,
Have installed Explorerhat and have bought an explorerhat pro, but my install on Raspberry Pi3 doesn’t seem to have worked properly.
With the EHpro on my Pi, if I run ‘import explorerhat’ I get loads of error codes - I have installed using a virtual environment and there are folders with the modules stored on the pi, don’t know what to do.
Here are the error codes from Python:
Explorer HAT Pro detected…
File “/home/perfectstorm/mu_code/bois.py”, line 1, in
import explorerhat
File “/usr/lib/python3/dist-packages/explorerhat/init.py”, line 756, in
touch._add(one=CapTouchInput(4, 1))
File “/usr/lib/python3/dist-packages/explorerhat/init.py”, line 595, in init
_cap1208.on(channel=self.channel, event=event, handler=self._handle_state)
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 386, in on
self.start_watching()
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 400, in start_watching
self.async_poll.start()
File “/usr/lib/python3/dist-packages/cap1xxx.py”, line 208, in start
if self.isAlive() == False:
AttributeError: ‘AsyncWorker’ object has no attribute ‘isAlive’. Did you mean: ‘is_alive’?
