Automation HAT Mini on pi zero
Good evening.
What is the correct procedure to install an automation hat mini on a raspberry pi zero with raspbian light ?
The procedure suggested on the site installs a working system for the automation hat and for the phat.
The system is not working for the mini however.
Also, the examples are not fully copied (hat-mini lacks).
Any help greatly appreciated !
Guibert
What is not working? What happens when you run the installer?
curl https://get.pimoroni.com/automationhat | bash
Do you get error messages etc?
Are these the examples your running?
The installation runs ok.
The examples from hat-mini are however not installed by the installation procedure.
When I copy the examples from hat-mini, when executed, no module ST7735 is found.
The older examples (hat) run flawlessly on the mini (as if it were a phat).
I will ty another install tomorrow with a full Rasbian on a pi 3B, and see what it gives.
Any other suggestions ?
Guibert
I had a feeling that was going to be what you’d say.
ST7735 is I believe the LCD display. This one I think?
The installer for that is
curl https://get.pimoroni.com/st7735 | bash
Good morning !
Thank you for your response.
Actually, I did take these steps (for st7735) yesterday even before your reaction came.
But then other things came up.
When I run output.py in the hat-mini folder, I now get this error message:
output.py
This Automation HAT Mini example toggles and displays the
status of the three 24V-tolerant digital outputs.
Press CTRL+C to exit.
File “./output.py”, line 52, in
spi_speed_hz=4000000
File “/usr/local/lib/python3.7/dist-packages/ST7735/init.py”, line 156, in init
self._spi = spidev.SpiDev(port, cs)
FileNotFoundError: [Errno 2] No such file or directory
One step further ?
Guibert
Problem solved !
I browsed the ST7735 init.pi file.
the spi-interface was not activated.
Thanks for helping me out.
Have a nice weekend.
And remain careful, stay safe and healthy.
Guibert
My forum e-mails for what ever reason are going into my Outlook Spam folder. Which is kind of messing things up for me reply wise.
I had a similar issue with the 1.3 inch SPI one. SPI wasn’t enabled, at least that’s what I think happened. Anyway enjoy your new toy. =)
