Automation hat tolerance levels
Ahoy mateys!
I’d be thinkin’ of trying the automation hat on me vessel Emely Raven which be powered with a 24 volt system. However power might be higher when chargin’ from land or generator
Would it tolerate up to 32 volt on the relays and would I be needing to divide me voltage to measure her batteries when chargin’?
Hello again - what I was wondering was what voltage the Automation hat can handle? since charging a 24-volt system might lead to higher voltages (30+)
best regards,
Daniel
http://e.phu.se
Automation HAT is only designed for 24V so make sure you stay within that limit!
