Hello,
I am looking to use the Automation Hat on a project that would use a 24vdc input to determine if a circuit is active or not. The problem is the it is an engine run circuit and between the belt driven battery charging alternator or the battery charger my 24vdc could at times be as high as 28-31 vdc. Is 24vdc rating a maximum value?
