Automation Phat, on Octoprint server
When trying to run the examples after a successful download of the automation hat file I get this error.
File “/home/pi/Pimoroni/automationhat/examples/output.py”, line 5, in
import automationhat
ImportError: No module named automationhat
Not sure what the issue is.
Just checked continuity on all of my pins, and they are good. (going from Pi to pHat), I also plugged in the 5v from the power supply to the normally closed spot on the relay, and it powers up just like I want. I don’t understand why the python code will not work, but it seems to be having trouble mounting the directory.
Any thing helps!
I also found a similar issue and ran this code.
i2cdetect -y 1 Here are the results
sudo i2cdetect -y 1
40: – -- – -- – -- – -- 48 – -- – -- – -- –
70: – -- – -- – -- – --
How did you install the Python library?
I tried a few different methods. I tried the curl link, and it installed all the directories and I can see them. I also tried from the desktop by installing pimoroni, and then going through the GUI to install automationhat
